I implemented SVPWM and Tdead using C block code
But I have some problem. When I switch on Gate signal to IGBT, the switch have delay which is same with simulation time step. Is it normal?
If I change some input values which are applied to C block, the output delay is generated which is same with simulation time step too.
Does PSIM consider device and code propagation delay?
