my question is related to a free-size optimization of a metal sheet done with shell-elements.
The model is simple, because it is not for application, but to compare it with the results of a SIMP-method topology optimization.
So there are no manufactoring restrictions.
Objective: min compliance
Restriction: volume max 30% of designspace
Base thickness: 0.0
So the result needs to be interpreted, because there are void areas after optimization.
I would like to do this using Isometric lines depending on thickness in Hyperview
and then use OSSmooth for fe-reanalysis with the threshold-value I got from Hyperview.
But when I do this, it seems like I can not get the thickness-distribution of the optimized design
for the fe-reanlaysis.
Can you tell me a way to solve it?
