I have been trying to eliminate the element concentrations caused by HM 3D tetra remesh for a couple of months now and yet there is no robust solution available.
I wonder if it is possible to extract a surface mesh from the 3D mesh components - for instance the front surface in attached pic and then remesh the surface mesh in a 2D manner. Later, after the new surface mesh is created, apply the 3D remesh feature to the entire mesh component basing on the new surface mesh.
Would it be feasible in HM? How can I possibly extract the surface mesh and remesh it with certain 'feature angle' parameter to filter out the wanted small segments? and can I use 3D tetra remesh with pre-defined 2D surface mesh?
Answer to any of these questions would be most welcome.
Many thanks,
Wensong
