How do I set the hard stop distance (where the spring is maximally compressed) for a Spring Damper object?
Philip Oesterle-Pekrun
Philip Oesterle-Pekrun Altair Community Member
edited January 2024 in Community Q&A
I am using the Vehicle Tools extension in MotionView, which I guess is in some way a part of HyperWorks (or now renamed to HyperMesh?) 2023. Basically my model stems from selecting this after opening "HyperMesh 2023":
So, on to the actual issue at hand. Whether I use the Vehicle Tools assembly wizard from the Vehicle Tools Ribbon or create a "Spring Damper" component from the Model Ribbon, I am unable to see an option to set the hard stop or maximum compression distance of the spring damper. When I set the spring stiffness to a small value like 0.1N/mm (for a car weighing about 1Ton) and run a simple NPost Simulation, the spring has some maximal compression beyond which it will not go. That shows that there is a hard stop for the spring, but I do not know where I can edit this value. I have looked everywhere for it, including in the (by default seperate) damper system (also a spring damper, but with 0 stiffness and a finite damping coefficient). In every spring damper component you have these same options:
I have checked the documentation, and it does not mention hard stops or maximum compression distance. But as I explained, the value for the hard stop must exist by default, as the springs clearly have a certain default maximum compression distance in simulations. I will greatly appreciate any help on this. It is a simple issue but really holding up my workflow. Thanks.
Here are screenshots of the modelling window and simulation result for context:
(vehicle body hidden in mdl)
(you can clearly see that, at 0.1N/mm, the springs compress a maximal distance at a hardstop)
Best Answer
