Hey,
I need to model a bolt/pin in a 3D structure. I have been using RBE2 elements (this is the way the bolt connector does it to correct?), however my problem is that if I bolt 2 parts together the bolt in reality should exert a bearing force on the connected parts. However the RBE2 elements naturally push on one side of the hole and pull on the other side, this pulling action is unrealistic.
Does anyone know how to better specify a bolt, or to set the rigid elements to be compression only?
Thanks
