I try to optimize the cross section of a beam using optistruct (diameter and thixkness).
I'm student and I am not sure of what I am doing.
When I try to set the design constraint with optistruct I use the static stress response in order to fix a limit of 300Mpa.
As I'm using 1D element I can't obtain the stress into the cross section of the beam so my design limit (300Mpa) cant be used by Optistruct !!!
Does anybody know if it is possible to obtain such a stress distribution in order to optimze the geometry of the beam cross section ?
Maybe I'm not using the appropriate method in order to optimize the cross section of a cantilever beam !
Regards.
Florent.
