In our supervisory system, we want to start a motor from zero speed using direct-on-line (DOL) starting with the load coupler engaged. The main concern is that once the motor speed reaches the desired speed, the load coupler should disengage and record its time and position. In other words, for example, the electric motor starts from zero during start-up, we want it to stop at a certain speed (for example, 520 rpm) and the time and position of the rotor at this speed can be obtained.
Thank you for your guidance
