I have been trying to create a solid mesh comprised of only HEX8 elements. I have been using the 3D solid mesh tab. In this tab I choose the ONE VOLUME option. I pick a solid to mesh, and subsequently mesh it. But I noticed that there is a SOURCE SHELL tab where I can choose quads, trias, or mixed. I am able to mesh the entire construct, but in so doing a layer of shell elements is created. This layer of shells is unwanted because I feel that a mixture of shell and solid elements in a single part will yield an error when I run the simulation.
Is there a way to avoid this creation of shell elements and attain a mesh that is composed solely of HEX elements?
Additionally, this HEX mesh will be treated as a fluid. To do so are there other meshing parameters that must be set? Or is this done in the ALE_REF_SYS_NODE and GROUP panels only?
Thank you, any help would be greatly appreciated.
Brad
