Creating a System with one of the axis normal to surface.
Altair Forum User
Altair Forum User
Hi all, my name is Lucas.
I have met a problem with creating the system with one of the axis normal to particular surface. Basicaly imagine that you have a 'lips' and on the edge of it you want to creat a System with one axis normal to the curved surface? I vas trying several option but I have failed. Maybe someone over here have similar task, and was able to do it?
Welcome!
  • Altair Forum User
    Altair Forum User
    edited April 2012
    Hi Lucas,
    i don't understand what you mean.
    A curved (Nurbs) surface has a different normal axis at each point.
    For a flat surface it is very simple...
    Mario
  • Altair Forum User
    Altair Forum User
    edited April 2012
    You can get a normal vector by:
    Create nodes along a curve.
    Offset the curve.
    Create the same number of nodes along the new curve.
    Create a normal vector from two nodes
    But, not sure how to get the tangent node you need to create a system.
  • Altair Forum User
    Altair Forum User
    edited May 2012
  • tinh
    tinh Altair Community Member
    edited July 2012
    Hi Lucas
    so the problem is you could not find out the normal of that surface?
    1) if the system origin is not in that surface, you can project a copy of origin normally to surface, you will get the normal of surface by 2 nodes
    (origin, copied_origin), then you can specify axis for system
    2) if the system origin laying on that surface, you can associate it to surface, using tcl command hm_getsurfacenormal to get normal vector of surface at system origin node
    then using *createvector, *translatemark to create 2nd node on normal vector direction
    or another way, you can also use Surface Edit/Offset to offset a copy of that surface then respectively project normally to 2 surfaces to get normal vector
    rgds,
Welcome!
Welcome!
