🎉Community Raffle - Win $25
Join and Win
Creating a System with one of the axis normal to surface.
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi all, my name is Lucas.
I have met a problem with creating the system with one of the axis normal to particular surface. Basicaly imagine that you have a 'lips' and on the edge of it you want to creat a System with one axis normal to the curved surface? I vas trying several option but I have failed. Maybe someone over here have similar task, and was able to do it?
Regards,
1 - 4 of 41
    Altair Employee
    OP
    Hi Lucas,
    i don't understand what you mean.
    A curved (Nurbs) surface has a different normal axis at each point.
    For a flat surface it is very simple...
    Regards,
    Mario
    Altair Employee
    OP
    You can get a normal vector by:
    Create nodes along a curve.
    Offset the curve.
    Create the same number of nodes along the new curve.
    Create a normal vector from two nodes
    But, not sure how to get the tangent node you need to create a system.
    Altair Employee
    OP
    User: "tinh"
    Altair Community Member
    Updated by tinh
    Hi Lucas
    so the problem is you could not find out the normal of that surface?
    1) if the system origin is not in that surface, you can project a copy of origin normally to surface, you will get the normal of surface by 2 nodes
    (origin, copied_origin), then you can specify axis for system
    2) if the system origin laying on that surface, you can associate it to surface, using tcl command hm_getsurfacenormal to get normal vector of surface at system origin node
    then using *createvector, *translatemark to create 2nd node on normal vector direction
    or another way, you can also use Surface Edit/Offset to offset a copy of that surface then respectively project normally to 2 surfaces to get normal vector
    rgds,
