Creating a System with one of the axis normal to surface.
Hi all, my name is Lucas.
I have met a problem with creating the system with one of the axis normal to particular surface. Basicaly imagine that you have a 'lips' and on the edge of it you want to creat a System with one axis normal to the curved surface? I vas trying several option but I have failed. Maybe someone over here have similar task, and was able to do it?
Regards,
You can get a normal vector by:
Create nodes along a curve.
Offset the curve.
Create the same number of nodes along the new curve.
Create a normal vector from two nodes
But, not sure how to get the tangent node you need to create a system.
Hi Lucas
so the problem is you could not find out the normal of that surface?
1) if the system origin is not in that surface, you can project a copy of origin normally to surface, you will get the normal of surface by 2 nodes
(origin, copied_origin), then you can specify axis for system
2) if the system origin laying on that surface, you can associate it to surface, using tcl command hm_getsurfacenormal to get normal vector of surface at system origin node
then using *createvector, *translatemark to create 2nd node on normal vector direction
or another way, you can also use Surface Edit/Offset to offset a copy of that surface then respectively project normally to 2 surfaces to get normal vector
rgds,
Hi Lucas,
i don't understand what you mean.
A curved (Nurbs) surface has a different normal axis at each point.
For a flat surface it is very simple...
Regards,
Mario
