** RUN KILLED : ENERGY ERROR LIMIT REACHED
Hey
I am simulating a bumper beam with radioss,
but when calculating, the time starts to increase and after a while occurs this message:
WARNING INTERFACE 3
NODE 1535259 DE-ACTIVATED FROM INTERFACE
and then:
MESSAGE ID : 205
I tried to different element formulations, set inacti to 6. (there are no global penetrations)
changed the material, changed the elementlength etc.
How can I avoid this message?
HI,
What is the interface type you are using?
Can you increase the minimum gap in the interface?
0 -
I'am using Interface type 7.
My shellthickness is 2mm so I used 1mm for Minimum gap.
When I use for example 2mm
this warning occurs:
** WARNING IN INTERFACE GAP
DESCRIPTION :
-- INTERFACE ID : 3
-- INTERFACE TITLE : all vs all
MAXIMUM VARIABLE GAP=2.000000000000
HOWEVER GAP IS RECOMMENDED TO BE LESS THAN 1.752438733029
POSSIBLE IMPACT NUMBER: 1426 (<= 1 *NSN)0 -
Warning due to interface gap is because of the GAP defined in the type 7 keyword. Attached document should give you more information on this.
Regards
Rahul R
0 -
I get the same error for some reason. Can you help?
WARNING INTERFACE 2
NODE 5 DE-ACTIVATED FROM INTERFACEMESSAGE ID : 205
0 -
Hi Ravin,
Try changing your normal direction for plate and the rigid body thickness 10e-14 is too low.
Also check the material properties and velocity of impact for high energy error
