conversion between solver format
Altair Forum User
Altair Forum User
I set up the FE model under the user profile of Abaqus in Hypermesh.
But now I need to carry out a Topology Optimization for the that model.
So I need to convert the model from Abaqus format to Radioss(Bulk data format).
The online help documentation gives some clues
(HTTP://www.altairhyperworks.com/(S(3fu2zyrlbyi03xcofiue25jd))/hwhelp/Altair/hw11.0/help//engsol/engsol.htm?conversion_between_solver_formats.htm and http://www.altairhyperworks.com/(S(3fu2zyrlbyi03xcofiue25jd))/hwhelp/Altair/hw11.0/help///hwd/hwd.htm?radioss_bulk_data_format_to_abaqus_conversion.htm).
But they are not so explicit.
According to the online help, It is a file 'ConfigurationFile.txt' that dominates the conversion process.
But this txt file addresses only four aspects, namely element type, material, property, and BCs&loads.
Now I wonder that can I edit this txt file so that element sets or node sets, contact pairs can also be converted properly?
I'm a beginner with HyperWorks, and I'm looking for your help! Thanks!
  • Altair Forum User
    Altair Forum User
    edited March 2013
    one basic method is (not always gives perfect results but i usually use),
    - backup your data first,
    - open the abaqus model with abaqus template,
    - change your template from abaqus to radioss bulk,
    - update all elements (1d and 1d&2d),
    - export it and import it with the new template,
    - check your model
    let us know that it worked or not image/emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'>
