Hi, I have created rigids (Beam), but i havn't checked the box attached dependent nodes as sets. Now how can i delete the sets or detach the nodes without deleting rigid?<?xml version="1.0" encoding="UTF-8"?>
Hi Balaji,
You can use Detach option to detach elements from nodes/elements.
Go to 1D page>> Detach to access the panel.
hello Mr. prakash
i do have a some problem. i followed your process and i give detach nodes.
again i try to delete the set . but same problem occurs again. i.e: rigid element also got deleted.
so could you help me in that.
thanks in advance.
Switch to 1d>rigids>update
You will se option 'attach/detach set'
Uncheck 'attach dependent nodes as a set' and update your rigids, then you can delete the sets
Great..
thank you so much Mr.tinh
