How to detach dependent node sets created while making rigid
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi, I have created rigids (Beam), but i havn't checked the box attached dependent nodes as sets. Now how can i delete the sets or detach the nodes without deleting rigid?<?xml version="1.0" encoding="UTF-8"?>post-37060-0-39545900-1430307895_thumb.p
1 - 4 of 41
    Altair Employee
    OP
    Hi Balaji,
    You can use Detach option to detach elements from nodes/elements.
    Go to 1D page>> Detach to access the panel.
    <?xml version="1.0" encoding="UTF-8"?>post-7616-0-52578300-1430369179_thumb.jp
    User: "NVH GURU"
    Altair Community Member
    Updated by NVH GURU
    hello Mr. prakash
    i do have a some problem. i followed your process and i give detach nodes.
     again i try to delete the set . but same problem occurs again. i.e: rigid element also got deleted.
    so could you help me in that.
    thanks in advance.
    User: "tinh"
    Updated by tinh
    Hi,
    Switch to 1d>rigids>update
    You will se option 'attach/detach set'
    Uncheck 'attach dependent nodes as a set' and update your rigids, then you can delete the sets
    User: "NVH GURU"
    Updated by NVH GURU
    Great..
    thank you so much Mr.tinh
