Please help me for the error FILE*.rst NOT FOUND
Thanks for advance
Here is error:
** ERROR: FILE frot_0000_0001.rst NOT FOUND
ERROR TERMINATION
application called MPI_Abort(MPI_COMM_WORLD, 2) - process 0
[8:woinic-0-3.local] unexpected disconnect completion event from [0:woinic-0-4.local]
Assertion failed in file ../../dapl_conn_rc.c at line 1179: 0
internal ABORT - process 8
[4:woinic-0-4.local] unexpected disconnect completion event from [8:woinic-0-3.local]
internal ABORT - process 4
= BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
= PID 11018 RUNNING AT woinic-0-4
= EXIT CODE: 2
= CLEANING UP REMAINING PROCESSES
= YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
