internal programming error in contslv_AN.F at location #200
I am using HYPERMESH 12 and working on foam core sandwich composite. Core is a non linear material where as skin is carbon/epoxy composite.
While solving my model in OPTISTRUCT i get this error msg
Is there any connection of this error with below mentioned points-
a) When I switch on my 'traditional and 3D element representation' and 'Composite layer' i get a message at the status bar i.e. 'not able to create normal of element'. While creating the ply it didn't say that but now it is giving this error when i am switich on my plies.
/emoticons/default_cool.png' alt='B)'> Is it compulsory to maintain mesh connectivity? I had to compromise it at few curvature areas where i couldnot maintain mappability.
I can connect through Web ex if you want to see the model.
Thank you
Hi Soumya,
what is the version of HW are you using?
Do you have contacts in your model and also 1D elements??
The problem is due to bad elements in contacts. This issue has been fixed in 13.0
0 -
Hey,
I hav tie tie contacts in the model. I am having 3D elements there are no 1D elements. I am using HYPERMESH 12.
I have already remeshed my model but still the problem is persisting. What shud I do to correct it?
0 -
Hi Soumya,
Please share the .out file with us.
You can upgrade to HyperWorks 13.0 Student edition for free.
Try the same on 13.0 and check if are able to run the job to the complete.
0 -
can you add the option NODMIG to all OUTPUT cards. For example
OUTPUT, H3D, NODMIG and OUTPUT, PUNCH, NODMIG.
Could you please start the run and let us know if this worked?
0 -
I am not able to find that option in output card...
can you tell me step by step way of adding that NODMIG please...
0 -
Rahul,
Edit the deck in text editor and add NODMIG, save the file and run the same using OptiStrut solver manager.
0 -
светодиодный экран оптом
светодиодный экран для магазина
медиафасад стоимость
купить медиафасад
медиафасад купить
светодиодный экран для помещений
медиафасад цена
светодиодные экраны
медиафасад
светодиодный экран купить
светодиодный экран для улицы
медиафасады
светодиодный экран для сцены
светодиодный экран цена
уличный экран
дорожные табло0
