Error message Optistruct
Altair Forum User
Altair Forum User
Hello
Following error message appears by running Optistruct:
 *** ERROR #  15 ***
 CTETRA element 3918 is distorted (zero or negative Jacobian).
Do you know how to solve the problem?
Thank you in advance for your help.
  • tinh
    tinh Altair Community Member
    edited December 2017
    Hi
    In hm enter panel F10>3D
    Check 'tet collapse' 0.05 then fix the failed tetra
  • Altair Forum User
    Altair Forum User
    Thank you it worked now.
  • Altair Forum User
    Altair Forum User
    edited February 2018
    I have the same message but for Quad elements :
    A fatal error has been detected during input processing:
      *** ERROR #   15 ***
      CQUAD4 element    1429962 is distorted (zero or negative Jacobian).
    I tried a lot of things but i don't know how to resolve the problem.
    Thank you for your help :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
  • Altair Forum User
    Altair Forum User
    HI, @Thibaut  delete the element with ID 1429962 and a couple of adjacent element and recreate that patch of elements or Remesh that particular patch without deleting element and check if this helps.
  • Altair Forum User
    Altair Forum User
    Thank you for your answer, I succeeded to remesh one element which had an error but there is a last one that I'm unable to remesh or delete because it create more errors and the calculation can't be fulfilled :
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.c155498c02915889f34b0f27aa9e4471.png
    How can I resolve this problem ?
  • Altair Forum User
    Altair Forum User
    I've just seen I have too many quality errors as well (in the 'aspect ratio'). I don't know if this is possible to correct all this errors easily. :/
  • Altair Forum User
    Altair Forum User
    HI,
    Is it possible to share the model file, please?
  • Altair Forum User
    Altair Forum User
    No sorry it's confidential, I think I'll ask help of Hypermesh professional in my company.
    Thanks a lot for your help. :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
  • Altair Forum User
    Altair Forum User
    edited February 2019
    OptiStructtinh @GuestHi ! I have the same problem. And I check the  'tet collapse'. But I don't konw how to fix the failed tetra , can you hele me?
  • tinh
    Hi
    Do you try tetra remesh subpanel?
