Hi everyone,
There are 3 options in I_thick parameter (Shell resultant stresses calculation flag) in card Shell element property.
= 0: default set to value defined with /DEF_SHELL
= 1: thickness change is taken into account
= 2: thickness is constant
How should I choice this parameter?
Base on tensile test experiment data (Force - Extension), I converted the data to Plastic strain - Stress for using MAT36. The Stress - strain in simulation and enter data is the same. But the result has a problem. The Force - extension curves are the same until maximum force. The simulation extension is shorter than experiment extension. I think there are some problems in the rupture phase. Which one should I check?
Thank you very much!
