Hey Guys,
I want to simulate 2 pipes connected with a joint (spring with property P45KJoint2 connected with Rbody 1D elements at each end) under gravity force and a initial velocity falling on a rigid wall (ground).
Whenever starting Radioss the solver says following: ERROR ID : 274 ** ERROR IN RIGID BODY DEFINITION (INERTIA)
The model checker says that under error all points are checked, just at the warning section it says :'Rbody ID is different from Masters ID' with a cross...How can I get that checked too?
I also attached the file, so that you can have a better look at the issue.
Please be so kind to help me
