I am performing non-linear roof crush analysis using explicit method in optistruct.
I want to perform an optimization but before that i want to see the response of my model therefore I need only analysis before running optimization.
A rigid wall is moving towards my roof structure under a given velocity input.
The starter file is created without any problems but the engine file fails with the error message which is shown below when I execute the run.
*** ERROR # 4003 ***
Abnormal termination in NLGEOM subcases.
For details please refer to file :
Optistruct_...._0001.out
When I check the out and hwsolver.msg file it is not showing any more details but the same message like above.
Has anyone encountered with such a problem and what does it stand for?
Thanks in advance,
Emrah
