i did everything on tutorial but i have errors on bottle drop tutorial.
PART: 2,water ---- PROPERTY: 2,Water MATERIAL: 2,Water
ERROR ID : 42 ** ERROR IN PROPERTY/MATERIAL COMPATIBILITY DESCRIPTION : -- PART ID:2 HAS AN INCOMPATIBLE ASSOCIATION SUBSET : 0 VIRT. THICKN: 0.000000000000
PART: 3,air ---- PROPERTY: 3,Air MATERIAL: 3,Air
ERROR ID : 42 ** ERROR IN PROPERTY/MATERIAL COMPATIBILITY DESCRIPTION : -- PART ID:3 HAS AN INCOMPATIBLE ASSOCIATION SUBSET : 0 VIRT. THICKN: 0.000000000000
i fixed it error 639 but now there are error 42 , how can i fix it
Hi @gangstarr60
Looks like components have incompatible entities. Can you share the model file?
everything is on here
i did everything on tutorial but i had so much error then i changed element type on 3D to penta6dg then i changed properties to p20_tshell with Isolid=15 then became 2 errors
Hi
Can you change the property for air and water to solid instead of thick shell.
PFA,
When i did solid , i have so much errors , its code is 639 and there are 26 errors with solid
your tutorial is worked , but i did like that everything , what was my mistake ?
The problem is with the penta elements.
PENTA6 is somehow causing the problem and update penta element type to PENTA6DG. This works.
Okay thank you so much for helping , have a good day .
You too have a nice day @gangstarr60 /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20'>
I try to learn Radioss via tutorials. I run RD-3560 tutorial yesterday. But running have not finished yet . I think, the model is not big so running process should not take long time. Is there any problem? you can see .out file in attc.
Thank you
Hi Nihan,
From the out file we can see that the time step has drastically dropped, and that's why the run is taking more time to complete.
This time step drop can be because of an element, a node or an interface.
•For an element, check the related material (especially its Young modulus and density in case of an elastic-plastic material; and its viscosity in case of a visco-elastic material). There must not be an error in the units system that this data is given in.
Check the size of the element, since elemental length is proportional to time step.
•For a node, check the characteristics of connected elements. If the node is on the master side or the slave side of an interface, this interface must be verified.
•For an interface, the gap of the interface must be verified if some failure happens on the master or the slave side of the interface.
Once this is cleared you can run the simulation without time step being dropped.
In this case, it is an element and you can check the parameters mentioned. If the issue persist, please share the model file.
Hello George,
Thank you.
I checked model file. But there are 26 errors when it runs. I share model file.
Can you try modelling with the .hm file attached along. And please let us know the update.
I send .hm model.
Please try working on the example with the model file (bottle.hm) attached in the above reply.
Hey.
When i completed all my procedure on bottle drop test it still shows one error ie., error 178 (error in part definition property). Even though thickness is assigned. Plz help me out
Hi @Addy,
Can you check whether /PART card image is assigned to the components?
If it is assigned, please check whether property and material are assigned to component(s). Also, check the compatibility of property, elements used, material etc...
Can you share the complete starter out file, please?
Yes PART card image is assigned. I am Sharing my hm file here. Plz check it and help me out. Thanks
Hi @Addy
What was the error? I am unable to identify?
Hi @Addy There are few PENTA6 elements in Water and Air components which are not compatible with LAW37. So, changed the element type to PENTACG,
Hey Prakash.
Still same issue. Again it is saying property not assigned
The file runs fine at my end. This could be due to version issues.
Please apply property and try again
