Hi all,
i need to calculate a dynamic stiffness in a frequency response analysis.
The term stiffness is defined as follows:
i have a structure (free from RB-modes) and i put a force load on a node in it, which must vary sinusoidal with time. The force load will deform the structure and i want to monitor the deformation of a certain node in the structure, which lies a distance away from the load point. The stiffness now is calculated as force / displacement.
What i need for postprocessing is the stiffness-value described above plotted over a frequency domain for the force of about 50 Hz to 10 kHz. Is that possible in RADIOSS Bulk? How do i model the loading? Which Output requests will deliver the needed values from the Solver?
Many thanks in advance
