Hello. I am doing a topology optimization. The goal is maximum stiffness. Two responses are volfrac and compliance. Optimization constraint is 0.3 of total volume. 'Draw' manufacturing constraint with stamp options are applied.
On completion of optimization run, OptiStruct tells me small design change, iteration stopped. Then I check compliance values over iterations and find that in iteration 20 compliance value has increased dramatically, like 656%. Previous two iterations 18 and 19 has a massage saying 'the 1st satisfied convergence ratio = xxx(some numeric value)' and 'the 2nd satisfied convergence ratio = yyy (some numeric values)' respectively.
Can anyone help me identify the problem and tell me what is the meaning of the massage? Thanks!
