I nedd to help in two issues:
Type Material : MAT1
CASE: NON INEAR QUASI ESTATIC
MATS1 - PLASTIC DEFORMATION
MATT1 - VARIATION OF PROPERTIES
1. Stress-dependent and Temperature-dependent Material Definition MATS1
I'm doing an analysis that I add the stress - strain curve for plastic deformation of a material under different conditions of temperatura. For this, I created TABLES1 to each curve with different temperature values and I introduced in a TABLEST. In this case my question is:
The results of plastic deformation ¿Are an accumulation of calculating for each TABLES1 ? and ¿How can I to do observe the results for each curve in the same analysis?
2. Isotropic Material Temperature Dependence MATT1
I need to add changes in the material properties dependent,the temperature values, I created TABLEM1 for Young Modulus and other for de Poissons coefficient fot two diferent temperature values and integreted them in subcase material MATT1. But the next warnning appears:
' Temperature-dependent materials are present, yet no respective temperature field has been identified.
Temperature-dependent material properties will be ignored. Use TEMPERATURE(MATERIAL) in subcase section to specify material temperature set ID. '
Can you help me please..
Thanks in advance
Fer CM
