export 2D mesh
Altair Community Member
Updated by unknown
Hi all,
I am trying to export the 2D mesh from acusolve. As far as I know, in acusolve, we always create a 3D mesh. Acusolve only works with 3d mesh. The following is the domain I am working with.
The domain is 1m x 1m x 0.05m. I tried to export the mesh to Nastran to Gmsh to Matlab for my work. In gmsh, it shows 20602 elements (not 10100). I am thinking only surface meshes from all the faces have been exported and treated as 2D mesh.
How can I export only 2D mesh from top surface only (as in 2D simulation; mesh as seen from the top)?
1 - 1 of
11
1 - 1 of
11
I would guess you should mesh only the top surface - then export as Nastran or STL. Use Interactive or Surface in the Mesh ribbon > Mesh group.
