Hi all,
I referred to the following links:-
https://help.altair.com/hwcfdsolvers/acusolve/topics/acusolve/post_processing_programs_acutrans.htm?zoom_highlight=acuTrans
https://help.altair.com/hwcfdsolvers/acusolve/topics/acusolve/udfgetosidata_acusolve_udf.htm
But I could not find a way to write the mass average dissipation rate using the UDF. I could only use the acusolve data translator to write it but I want to use UDF for the same. Do you know how to do it?
Thanks.
It looks like that variable might be available - just not documented.
Please try with the variable UDF_OSI_MAV_DISSIPATION - then please update whether that works.
It looks like that variable might be available - just not documented. Please try with the variable UDF_OSI_MAV_DISSIPATION - then please update whether that works.
It seems it works but the values I got from the convert tool is different than the one I obtained using the UDF. I checked for the values in different time steps. It does not match exactly. May be because of averaging?
UDF => 0.542200827554
convert tool => 5.8018636166675785e-01
It seems it works but the values I got from the convert tool is different than the one I obtained using the UDF. I checked for the values in different time steps. It does not match exactly. May be because of averaging? UDF => 0.542200827554 convert tool => 5.8018636166675785e-01
I just noticed the value for UDF matches with the dissipation rate in convert tool not with mass average dissipation rate.
It could be a difference in the timing of the data. The UDF is probably using the data from the end of the previous time step. In other words, does the UDF-reported value match more closely with the ConvertTool/AcuTrans data from the previous time step?
Does UDF_OSI_CURR_MAV_DISSIPATION appear closer to the ConvertTool values?You might have access to
UDF_OSI_DISSIPATIONUDF_OSI_MAV_DISSIPATIONUDF_OSI_FMAV_DISSIPATIONUDF_OSI_CURR_DISSIPATIONUDF_OSI_CURR_MAV_DISSIPATIONUDF_OSI_CURR_FMAV_DISSIPATIONDoes the UDF report different values for each of those?
It could be a difference in the timing of the data. The UDF is probably using the data from the end of the previous time step. In other words, does the UDF-reported value match more closely with the ConvertTool/AcuTrans data from the previous time step? Does UDF_OSI_CURR_MAV_DISSIPATION appear closer to the ConvertTool values?You might have access to UDF_OSI_DISSIPATIONUDF_OSI_MAV_DISSIPATIONUDF_OSI_FMAV_DISSIPATIONUDF_OSI_CURR_DISSIPATIONUDF_OSI_CURR_MAV_DISSIPATIONUDF_OSI_CURR_FMAV_DISSIPATIONDoes the UDF report different values for each of those?
I checked the values for different time step. UDF_OSI_MAV_DISSIPATION matches with dissipation rate in convert tool not with mass averaged dissipation rate.
UDF_OSI_DISSIPATION and UDF_OSI_MAV_DISSIPATION both of them report same values in udf and those values match with dissipation rate in the convert tool.
For the rest of the data, I got compilation error. It says:-
error: ‘UDF_OSI_CURR_MAV_DISSIPATION’ undeclared (first use in this function); did you mean ‘UDF_OSS_CURR_MAX_DISSIPATION’? Real* e = udfGetOsiData( udfHd, "outlet_2 - Output", UDF_OSI_CURR_MAV_DISSIPATION ) ;
UDF_OSI_DISSIPATION and UDF_OSI_MAV_DISSIPATION both of them report same values in udf and those values match with dissipation rate in the convert tool. For the rest of the data, I got compilation error. It says:- error: ‘UDF_OSI_CURR_MAV_DISSIPATION’ undeclared (first use in this function); did you mean ‘UDF_OSS_CURR_MAX_DISSIPATION’? Real* e = udfGetOsiData( udfHd, "outlet_2 - Output", UDF_OSI_CURR_MAV_DISSIPATION ) ;
Thank you. I will report your findings.
I think that previous list is wrong. They should be 'MFAV' instead of 'FMAV' - but if none of the 'CURR' values work, this probably won't change that. Does
UDF_OSI_MFAV_DISSIPATION
work - and give the same as the other two, matching dissipation rate from Convert?
I think that previous list is wrong. They should be 'MFAV' instead of 'FMAV' - but if none of the 'CURR' values work, this probably won't change that. Does UDF_OSI_MFAV_DISSIPATION work - and give the same as the other two, matching dissipation rate from Convert?
Now it successfully compiles and UDF_OSI_MFAV_DISSIPATION in udf matches with mass flux averaged dissipation rate in convert tools. But the values are different.
Now it successfully compiles and UDF_OSI_MFAV_DISSIPATION in udf matches with mass flux averaged dissipation rate in convert tools. But the values are different. UDF_OSI_DISSIPATION--->0.542200827554 UDF_OSI_MAV_DISSIPATION--->0.542200827554 UDF_OSI_MFAV_DISSIPATION--->0.576175336021 convert tool: dissipation rate--->5.4220082755369303e-01 mass averaged dissipation rate--->5.7617533602060644e-01 mass flux average dissipation reate--->5.7617533602060644e-01
If I can summarize:
1 - None of the CURR values work.
2 - UDF_OSI_DISSIPATION and UDF_OSI_MAV_DISSIPATION work - but both match the Convert Tool value for dissipation_rate
3 - UDF_OSI_MFAV_DISSIPATION works - and matches the Convert Tool value for mass_flux_averaged_dissipation_rate (as one would expect)
Is that all correct?
If I can summarize: 1 - None of the CURR values work. 2 - UDF_OSI_DISSIPATION and UDF_OSI_MAV_DISSIPATION work - but both match the Convert Tool value for dissipation_rate 3 - UDF_OSI_MFAV_DISSIPATION works - and matches the Convert Tool value for mass_flux_averaged_dissipation_rate (as one would expect) Is that all correct?
Yes, that's correct.
