Hi
I have a pipe with non linear material , internal pressure and a force end of pipe , 2 load step, at the first step I have only internal Pressure and in second load step,Pressure+ Force. I have defined the force as pressure. after analyse I want to get force- Displacement (force end of pipe as pressure ) . I need force-time and displace-time curve but I have only one time . I need many time to get curve. what should I do?
Best regards
S.Faghfouri
