Is it possible to remove boundary layers from the solid domain and only include it in the fluid domain in the middle layer?
Yes, after specifying materials to the model make sure you have the Generate boundary layers on fluid domains only option checked while meshing.
Make sure you specify material before meshing.
Thanks!
