Hi all,
please find attached my very first issue with the optistruct pre processing that I am presenting here.
I did start a variation of batch jobs and do suddenly run into the following issue:
after a start of the batch job it is canceled and an *.out-file is returned with the following error message:
There were 4 error messages during input processing.
The first message is repeated below:
*** Problem(s) found while reading line 54379 from file: 5001int_5017int_fc.bdf
'CQUAD4 9901123299004011'
*** ERROR # 1000 *** in the input data:
Incorrect data in field # 4.
While checking the *.bdf-file which is written by Optistruct and in the same folder as the out file I do find:
CQUAD4 990112309900401199012272990122689901226999012286 1002
CQUAD4 990112319900401199012286990122699901227099012284 1002
CQUAD4 9901123299004011 (author remark: here do follow a lot of 'NUL''NUL'....)
$### End of include file ###
$### This is the original statement ###
$### INCLUDE 'RBE3s.bdf'
in the original 'INCLUDE-file' where optistruct gets the input from it says:
CQUAD4 990112329900401199012185990122879901228899012186 1002
CQUAD4 990112339900401199012186990122889901196399011962 1002
CQUAD4 990112349900401199012287990122829901228199012288 1002
CQUAD4 990112359900401199012288990122819901196499011963 1002
CQUAD4 990112369900401199012183990122749901228999012184 1002
It seems as optistruct is converting some of my input into 'rubbish'! :-(
Up to now it did always work. And - of course - I did not change anything ... ;-)
Does anybody has an idea where this might come from and how to solve it?
Thank you all in advance ... :-)
