GROUND CHECK
Dear All,
I have to see output in G-set, N-set, A-set, F-set... etc format like nastran for natural frequency analysis.
Will you please help me to get this output using optistruct?
Further i am not able to use ARG2(1) and ARG3(1) ?
What is value of ARG3(1)?
Thanks & Regards,
Rahul
Hello All,
Can anyone help me on above topic?
0 -
Are you running analysis in Optistruct ?I too dont see information on ARg2 & ARG3 in documentation. But it should work with ARG1 PRINT & Opion set to yes.
If get any error please share.
0 -
Yes Rahul i am running with optistruct. I have solved with ARG1 PRINT & Opion set to yes. I didn't get any error. But output format is not like nastran.
Below i have attached screen shots of Nastran & opti out file for GROUNDCHECK results.
I have to see GROUNDCHECK results same like Nastran using Optistruct... i mean in G- set, N-set, F-set etc....
0 -
Hi Rahul,
No options are currently available in Optistruct to get the output in G- set, N-set, F-set for Groundcheck.
0 -
Thank you George and Rahul R for valuable information.
Thanks & Regards,
Rahul
0 -
Hi Rahul K,
I think the answer is in your question. You get a fail because you are constraining the body and not allowing to move as a rigid. The same is reported back to you /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
GROUNDCHECK: From help ' perform a grounding check analysis on the stiffness matrix to expose unintentional constraints by moving the model rigidly. '
0 -
Okay Thank you Prakash /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
