I want to run an acusolve problem 4 times with same geometry, ic, bc, etc. except the inlet velocity=1,2,3,4 m/s. I want to use slurm job array for the same. Do you think I need to create separate directories for each problem? I will manually modify the input files. Do you think it would conflict the solution and log files?
Thanks.
