How to define a RWALL
Altair Forum User
Altair Forum User
Dear user and support,
I made a simpel system in OptiStruct: A RWALL which has a certain velocity is moving towards a pipe. My problem is that the RWALL is moving through the Pipe and doesn't deform it. I checked the contact definitions, but I think there are no mistakes so far. What could cause this problem? I can provide the model if you want.
Thank you very much!
  • Altair Forum User
    Altair Forum User
    edited November 2014
    Hi the_frik
    When defining RWALL have you added slave nodes?
    can you please check this?
    if this doesn't work, please share the model file with us using the dropbox link in my signature.
  • Altair Forum User
    Altair Forum User
    the_frik
    Can you re-create RWALL again and make sure you DO NOT specify any GSID2 in the RWALL card.
    <?xml version="1.0" encoding="UTF-8"?>post-7616-0-64472800-1415270448_thumb.jp
    <?xml version="1.0" encoding="UTF-8"?>post-7616-0-57964100-1415270497_thumb.jp
  • Altair Forum User
    Altair Forum User
    Dear all,
    the model/simulation is correct, but Prakash figured out that the problem is connected to the settings. Here the link on how to clear the settings:
    http://forum.altairhyperworks.com/index.php?/topic/13434-how-to-delete-settings-files/?hl=delete
    Thanks!
  • Rahul_P1
    Rahul_P1
    Thanks Prakash and Thanks the_frik for posting the answer with the file !  image/emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'>
  • Altair Forum User
    Altair Forum User
    Hi Erik,
    One other problem is when you defined the RWALL you have Included GSID2 (In RWALL card) which excludes the node from the rigid wall.
  • Altair Forum User
    Altair Forum User
    edited February 2015
    could I send you another similar problem. The rigid wall can't find the contact, although I had defined one.
    That would help me a lot!
    Thanks,
    Erik
  • Altair Forum User
    Altair Forum User
    Sure.
    please use the dropbox link to share the file.
  • Altair Forum User
    Altair Forum User
    Did you receive the model?
  • Altair Forum User
    Altair Forum User
    Hi Erik,
    I will share the modified file soon! image/emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'>
    changes made: Normal vector direction for RWALL is changed to -Z instead of Z
