Hi guys,
I have two simulations. Second simulation folder is inside the first folder.
%%%%%%%%%%%%%%%%% FIRST %%%%%%%%%%%%%%%%%%%%%
I have a configuration file, Acusim.cnf with
# date = Fri Nov 4 13:33:04 2022
problem = test
problem_directory = /home/user/simulation
working_directory = ACUSIM.DIR
process_modules = all
input_file = _auto
message_passing_type = impi
num_processors = 24
%%%%%%%%%%%%%%%% SECOND %%%%%%%%%%%%%%%%%%%
problem = test
problem_directory = /home/user/simulation/
input_file = _auto
num_processors = 24
But I call acusolve from terminal with command: acuRun -pdir /home/user/simulation/inside
I mean the two problems have same configuration file. Except that i call first problem with terminal command acuRun -pdir /home/user/simulation and second problem with terminal command acuRun -pdir /home/user/simulation/inside.
Are these simulations solving same problem or different problem? Does specifying flag -pdir -np in acuRun terminal command neglect/override what is written in the configuration file?
Thanks!
