Export results from cluster to Ensight
I was sent here coming from this topic right here:
I ran a case on our cluster and now want to export the results to Ensight format to postprocess in Hyperview, but AcuOut does not seem to find the results. I tried to open the case (.acs file) in Acusolve and export it using AcuOut. I assume this way only works right after a case as been solved locally. However, I need to export the files coming from another machine. How can one do this? By the way, I can't just open the .log file in Hyperview. I run shear thinning fluid simulations and when I try to open these in HV via the logfile, I get an error saying 'Time does not match' and I can't display all the time steps. Also, velocity and pressure are the only displayed values this way, although I set more than these. So this way is not an option, unfortunately.
Thanks for your answer. Acusim.dir exists of course. With the Reader Options tab, I did get all my output options to show up, but I still got the 'Time does not match' error. Until now, it only occured when I ran shear thinning (power law) cases, newtonian setups were no problem. When this happens, the displayed time steps do not match the results I expect. For example, the case at hand was the full geometry I am examining and I already ran parts of it (1 degree, 5 degrees of the rotationally symmetric body), so I know what to expect. The last displayed result of the full body is not what the other cases showed, which I ran on my local machine and exported to Ensight using AcuOut.
I just tried acuTrans. I opened Acusolve CMD prompt, navigated to my case and typed 'acuTrans -translate_to ensight' to test it. Unfortunately, it told me this:
acuTrans: *** ASSERTION in Function <iopCheckStr> File <iopLow.c> Line <2074>
acuTrans: *** data out of order: expected <nAoutVecs> found <nFields> in binary
file <ACUSIM.DIR/acusolve.2_0_x.out> token <8> near <nFields>
Is the message 'data out of order' maybe related to the issue I have described above? As far as I know, there is no GUI access.
Hi again,
I was wrong in my previous reply. The version installed on the cluster is 14.0 while my local version is still 13.0, so no wonder there might be compatibility issues. Sorry for that, no more searching needed I guess. I just tried H3D and while it did convert with AcuTrans without errors, Hyperview tells me this after a few messages: Error: Failed to attach results.
I got Acusolve 2017 installed locally an a machine to test a few things. By the way, I went to an Acusolve training session a few months ago and we were told to pick fixed time stepping over adaptive time stepping. After asking why, since every other program I know supports adaptive time stepping without a problem, we were given no details unfortunately. Maybe this was the reason. Also, I just tried opening a test run of AS2017 in Hyperview 14 using the .log file after the same case done with adaptive and fixed time stepping. When I try to apply the velocity contour plot, Hyperview just crashes and closes without a message. Using Ensight is no problem.
In order that HyperView reads the results correctly from .Log file, ACUSIM.DIR also needs to be present (That is the actual folder with results).
BTW, Ensight format is not required to read AcuSolve results. Either direct .Log file (with ACUSIM.DIR present) or H3D export.
For the case that you are not able to see the additional quantities, you could use the options in HV to enable reading of extended nodal outputs.See screenshot.
<img alt='ARPxYviRjy61AAAAAElFTkSuQmCC' height='403' src='data:image/png;base64,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
