Contact analysis
Once you are done with 3d mesh its recommended to delete 2d mesh.Here in your model you have 2d element without property.That is what creating problem of Error 2372.
Please delete element by config quad4 & tria3.
0 -
Thanks for the reply, but how can I get rid of the 2D mesh without compromising the 3D mesh?
Thanks in advance for your assistance.
0 -
Hi antonio93, for this you have to follow this steps :
-first do you 2D mesh
-create a new component named as 3D_mesh_name_of_component, so this will be normally your current component (if not, make it current : right click on it and click Make Current)
-Do your 3D mesh (2D to 3D)
-Create a new component named as 2D_mesh_name_of_component, so this will be normally your current component (if not make it current : right click on and Make Current)
-Move your 2D 'initial' mesh to the last component you created 2D_mesh_name_of_component. For this your have to go to Tools/Organize/Move : select only you 2D mesh (desactivate your 3D mesh to do it and do elems/display) and put it on your 2D_mesh_name_of_component.
-Delete the component you created 2D_mesh_name_of_component
It will normally remain juste the 3D mesh /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
GAYE
PS : If your have many component, do this steps it in every component
0 -
Hi Antonio,
Please share the .out file. Looks like some data is missing related to pyramid elements.
0 -
Hi Antonio93,
this i due to bad quality element (tet collapse, jacobian, mix angle, max angle...). Please have a look about quality index, see altair web side for more details: http://www.altairuniversity.com/modeling/element-quality/
If you want, you can desactivate the element quality check doing by the solver. To do so, you have to go to : Analysis/control cards/Param (use next boutton to find it if necessary)/Checkel--->No instead of YES. But bear in mind that if you desactivate the quality element check you can get poor result. So you must be careful to what you do !!
You can also see this for more details :
GAYE
0 -
Good morning
Thanks for all the help. I did as you said and the analysis was completed. Now I have two more questions to ask you. This is my model.
I would like to ask you how can I stiffen the surface subjected to pressure.
Also I would like to ask you why the deformation of the cylinder is as shown in the figures.
0 -
Geometry change would help you to stiffen like instead of half cylinder you can use block.Any other geometrical change you can do using hypermorph.
You can plot displacement along x,y&z axis.So plot displacement along radius of cylinder.
0 -
Good morning,
Thanks for the reply. You could describe to me the steps to get rigid the half-cylinder plane surface.
0 -
Thank you very much Rhaul.
0 -
Sir, I facing a same error ERROR 2372 No PSOLID properties exist in bulk data.
0 -
I think you forgot to define the property for your component .... or material on property ...
Can you please the *fem file ?
0 -
Altair Forum User said:I think you forgot to define the property for your component .... or material on property ...
My file size is 62.7 mb it exceeding the size is their any other way that I can send u
0 -
I crossed checked the component all. Property and material r been defined
0 -
Unfortunately, I can't help you without *fem file ! sorry mate !
Try to see if you have a duplicated mesh for example ...
0 -
Altair Forum User said:0
