Hi guys,
I have been working in a CFD simulation and to post-process the result, I was wondering if I would be able to obtain (or calculate) surface heat flux and average pressure exerted on a particular surface of a 3D geometry WITHOUT using post-processing programs like hyperview or hyperworks CFD post-processing.
Is it possible to define a command (may be in UDF or may be in acuTrace) to obtain those values as an output? If possilbe, how to do it? Do you know a tutorial for the same?
Thanks.
