I have created automation using standard trim hole macro.
i just wanna give center node for triming a hole around it. i have used standard macro TrimMeshWithCircle.tcl for this
and given my expected Hole radius as default and by default also ticked box for minimum no. of nodes
and i made changs in this file where BuildTKDialog method has been called as below methods called directly after that.
BuildTKDialog
Quit
MultipleTrimHoles
but it sometimes work and sometimes doesn't.
generally when i use it for first time i need to create couple of holes manually and then modified macro works.
Does anyone know how should i go for this.
or what should i make necessary changes to work this macro correctly at any time.
Thanks in advance.
