Hi all,
   I have a problem solving the project in the image below.
   It is a machine in which the mechanical set of the green face and the red face is set in 'translation along Ox'.
   The surrounding face (the face selected in the image) is air. Now, if the mechanical set of this face is setted 'fixed', the following solving error appears: ' executeAlgo_c : Execution failed'.
   Instead, if I change the mechanical set into 'compressible', the error message is: 'Unable to rebuild device because symmetries/periodicities create an infinite geometry'.
   I think I didn't understand completely the meaning of these mechanical sets or I made some errors with the periodicity. What can I do?
   Thank you everybody.
