i am looking for the definitions of pressure and total pressure coefficient (cp and cp-tot) for AcuFieldview.
I would be glad for your help.
Thanks in advance
I'm not sure I completely understand the question. The quantity written as 'pressure' by AcuSolve is static pressure (P). Total Pressure would be static pressure plus dynamic pressure - or P + 1/2 * Rho * Vel^2. You can create variables using math functions in AcuFieldView by f_x icon towards the top of the AcuFieldView main window.
Hi acupro,
sorry for the misunderstanding of my question. I will try to explain better:
For VWT Simulations i need to define the pressure coefficient to show the pressure distributions on a car. I think, the formula for that is following from ydigits description:
('pressure'-0)/(0.5*'vwtRho'*('velocity_magnitude'+'vwtVel')^2)
At this point, there are some questions: where is the variable 'velocity_magnitude' from? Theoretically it should be without velocity magnitude.
Why is the reference free stream pressure 0?
My expectation is to see the cp value 1 at stagnation point of the car. But it is around 2 or 3 according to VWT analysis report. How could it be like that?
I am a bit confused because of this. Maybe i miss an important point by the way.
Thanks for your help.
It seems there may be a mistake in that formula. You wouldn't sum velocity_magnitude and vwtVel - the 'velocity' term squared should be the overall freestream velocity, which is likely vwtVwl. The pressure difference would be the local static pressure P minus some reference pressure. You could use the integrated static pressure at the inlet for the reference pressure. I suppose you could also use the integrated pressure at the outlet, which may be 0 if that is the boundary condition used. So long as you always use the same definition, then your comparisons would be valid.
Thanks acupro. I will try with the inlet static pressure.
