Hi everyone,
I am trying to perform thermal simulation with heat source and sink as boundary condition. I have a positive heat flux(as QVOL acting on solid elements) and a negative heat flux (as QBDY1 acting on conduction interface). However most of the time I could see that the simulation does not converge and the Temperature results are very big.
Attached here I have 2 fem files with exactly the same geometry and boundary condition and element size, but different meshing directions. the 1.fem file yields correct results while 2.fem doesn not converge. I have tried to experiment with changing element normal and changing material direction all to be along heat transfer direction but still 2.fem file does not converge and I cant find what makes the difference in simulation results.
can anybody check to see if you can converge the 2.fem file ? and what makes 2.fem file not converge?
thanks and looking forward to hear from you
Rafezi
