Hello Altair Team,
I would like to get more knowledge about the Radioss solver and especially about how linear subcases are handled.
In Abaqus, there is a time step control even within the absolutely linear subcases. Time has no physical meaning there but it is used to control how the load is applied to the model.
As I understand it, the solver tries to find the equilibrum of outer force applied and inner foce (calculated through the compliance matrix). For that there is this one equation, which says: Outer forces - inner forces must be Zero! This is the case at the equilibrium because there are no accelerations (-> Newtons Law.)
So;
1) Newton Solver: Even if the case is completly linear, I have those iterations in order to find the equilbrium
2) In linear Subcases the Newtonsolver tries to find the equilibrium on 100% of the outer load applied.
Questions:
1) How is the load applied. In Abaqus there are several functions... eg. ramp, parbolic... is there something like this in HM. How it is done there?
2) What if it fails... no equilibrium found... is there a basic handling? Like reducing the stepsize of load incremental?
I think this is enough for now.
Thanks in advance...
Manuel
