Hey guys,
how it is possible to limit the timestep?
In the beginning of generating the model I want to get the results in 1 hour, not even 2 days.
I tried with
/DT/NODA/0
0.000e+000 1.000e-001
but it doesn´t work. I also tried to change the second value, but nothing happened.
In addition to that I have to check the tensile stress and compression stress. For VonMises I use
/ANIM/BRICK/TENS/STRESS. What is the command for the tensile/compression stress?
Thank you,
Manuel
