Hello All,
I am doing geometry nonlinear static analysis on a lattice structure using Optistruct and during model organization, I am facing lot of problems that I am not able to solve, like -
- I have a lattice CAD model in form of a 2D mesh ( 441964 nodes, 892864 elements), then I am doing initially this 2D mesh convert into the 3D tetrahedral mesh (608588 nodes, 2171299 elements) using the 3D panel in HM.
- Before doing this conversion, I checked the quality of 2D elements and then convert into the 3D tetra mesh. But during the 2D elements quality check, there is some large number of elements are failed in skew, trias min and max angle e.g. (Skew (60) 163 of 892864 (0%) failed. It is difficult to correct the failed elements because the number of the failed elements are very large, it will take a lot of time.
- Next, after conversion 2D trias to 3D tetra elements, I deleted 2D elements then provided input details like material, properties, load collector and load step.
My question is that
- when I do the static linear analysis so analysis was completed, but when I do geometry nonlinear static analysis some error showing and analysis has not completed.
I provide all input data that required for geometry nonlinear static analysis. I am thinking that due to a large number of 3D tetra elements fails, therefore the nonlinear analysis not complete.
Please guide me, how can I do fastly to correct those fails elements.
I am trying but I am not able to do it fastly.
