Fatigue Analysis of Diesel Engine Piston
Altair Forum User
Altair Forum User
Want to do fatigue analysis of diesel engine piston as the part of master's thesis.
Initially I have tried out a 2D fatigue analysis problem of a mild steel strip and got the results.
Then tried to do the fatigue analysis of piston using the same material and same method.
I got good VMS and displacement values for the static sub-case and the pictures are attached.
post-4480-0-17893600-1374573108_thumb.jp
But for the fatigue sub-case didnt give the necessary results.
post-4480-0-19233200-1374573128_thumb.jp
and
post-4480-0-14131000-1374573214_thumb.jp
I have followed the same method of 2D problem,PSOLID element is used for the analysis of piston.
(higher order tetrahedron element-10noded element)
Hope the wrong result is caused due to the lack of adjustments in converting a
2D problem to a 3D problem,like the changes needed for defining CARDS etc.
Varying pressure with respect to crank angle,for 100 cycles is applied for this fatigue analysis of Piston.
Please Help...
Ayyappadas
Welcome!
Welcome!
