I see the following error:
Error 33270: A triangle edge is too short or EPSENT is too large.
What does it mean and what should I do to fix it?
The error refers to a problem in the mesh. Often the fault originates in the geometry, for example, an extremely narrow face meshed into triangles will cause this error.
