I am actually working on a simulation of a piston.
Therefore I applied the mechanical loads but I also want to include the thermal stresses in a seperate loadstep .
Is there an easy way to import a table with temperatures?
I found a solution that I split the piston into several parts in relation to the heigth. And the themperature on the nodes are referred to a formula T0 +z*Delta_T for each part of the piston
But this is very inaccurate and needs a lot of time to apply the temperature field.
Many thanks in advance
