I'm currently learning some optimization tools and there is one required step, which I can't find on Hypermesh:
I need a specific manufacturable ply thickness, which normally should pop-up in the card image when 'PLYTHK' is chosen but it is not there. Only the fields 'PTMIN, PTMAX, PTOPT, PTSET and PTEXC' can be found on the card image. Do you know, how to find 'PTMAN' in another way? I am working with HW12 btw. Thank you.
Best regards
