Would some one help me please. I want to do non linear static analysis on a plastic component. The plastic is ABS and We don't have the stress strain curve of this material the only info we have are shown in the below table. Is there any way to define this plastic material with out having the curve?
Here is problem description
The following shows the part. The boss breaks due to applying 1nM torque in the center of the boss in real case
This is the result (in this case, It is assumed that material is in elastic domain). The result of analysis shows the maximum stress of 133 Mpa and the yield stress based on the material data in the above table shows is 49 Mpa
Can I from this model that, the part has failed since the maximum stress is more than the yield stress and confirm what is happening in reality (breakage of the boss)??
