How to create vertical scroll bar for window
hello everyone I have created a window using hwt::CreateWindow win
I have added only one row now to reduce size of Quote. Number of rows in actual script are in loop so my number of rows sometimes exceeds 100. So I need scroll to window.
So how can I add scroll to it
And I seardched for hwt::CreateWindow win help for all pther commands help is easily available in HM help but I didnt find any help related to these commands, So anybody direct me to proper help for hwt commands and specifically hwt::CreateWindow win
proc ::compQuery::window {} {
variable str_slave;
variable str_master1 '';
variable str_master2 '';
variable str_master3 '';
variable str_master4 '';
variable str_master5 '';
variable str_master6 '';
variable str_master7 '';
variable str_master8 '';
variable e1;
variable e2;
variable l1;
variable l2;
variable e3;
variable l3;
variable e4;
variable l4;
variable e5;
variable l5;
variable e6;
variable l6;
variable e7;
variable l7;
variable e8;
variable l8;
variable ang_incr;
variable def_val;
set dlgWidth [ hwt::DluWidth 100 [ hwt::AppFont ]];
set dlgHeight [ hwt::DluHeight 250 [ hwt::AppFont ]];set min_dlgWidth [ hwt::DluWidth 250 [ hwt::AppFont ]];
set min_dlgHeight [ hwt::DluHeight 200 [ hwt::AppFont ]];hwt::CreateWindow win \
-minsize 200 100\
-maxsize 2000 2000 \
-noGeometrySaving \
-geometry ${dlgWidth}x${dlgHeight} \
-cancelButton Cancel \
-defaultButton Cancel \
-acceptButton Accept \
-minSize $min_dlgWidth $min_dlgHeight \
-acceptFunc '::compQuery::GetcompVar' \
-cancelFunc '::compQuery::Cancel_func' \
-windowtitle 'Stress contour capture script' \
-post;#Create recess to hold frames
set recess [hwt::WindowRecess win];
grid columnconfigure $recess 1 -weight 1 ;
set l1 [::hwtk::label $recess.l1 -text 'Evaluation criteria for Max principal stress:']
set e1 [::hwtk::entry $recess.e1 -width 200 -takefocus 1 -help 'Entered value is max limit above this shown as grey colour' -textvariable ::compQuery::str_master1];
grid $l1 -row 1 -col 0 -sticky w -padx 4 -pady 4;
grid $e1 -row 1 -col 1 -sticky e -padx 4 -pady 4;
#default value $recess.e1 set 315;
hwt::KeepOnTop win
Hello tinh
do you have any example for these suggested method and which one will be best to use in current case
I studied some help on web now I am able to get scroll bar but not able to fix content in between scroll bar
Now I am doing trial and error to get final out come
mean while can anybody look at my script and suggest improvement
namespace eval ::compQuery {
variable ang_incr;
variable def_val;
variable str_slave;
variable e1;
variable e2;
variable k1;
variable k2;
variable k3;
variable k4;
variable k5;
variable k6;
variable l1;
variable l2;
variable e3;
variable l3;
variable e4;
variable l4;
variable e5;
variable l5;
variable e6;
variable l6;
variable e7;
variable l7;
variable e8;
variable l8;
variable ang_incr;
variable def_val;set dlgWidth [ hwt::DluWidth 100 [ hwt::AppFont ]];
-minsize 200 100\
-maxsize 1000 100 \
-noGeometrySaving \
set types {
{{H3D File} {'.h3d' } }
{{OP2 File} {'.op2' } }
{{All Files} * }
}grid columnconfigure $recess 1 -weight 1 ;
set z [tk::listbox $recess.z -yscrollcommand '.ss set' -xscrollcommand '.s set' -height 5 -width 20]
set y [ttk::scrollbar $recess.ss -command '.y$ yview' -orient vertical ]
set x [ttk::scrollbar $recess.s -command '.x xview' -orient horizontal ]
grid [set z] -column 0 -row 0 -sticky nwes;
grid [set y] -column 1 -row 0 -sticky ns;
grid [set x] -column 0 -row 1 -sticky ew
for {set j 1} {$j <= 4 } {incr j} {
insert end set l$j [::hwtk::label $recess.l$j -text 'Evaluation criteria for Max principal stress:']
insert end set e$j [::hwtk::entry $recess.e$j -width 200 -takefocus 1 -help 'Entered value is max limit above this shown as grey colour' -textvariable ::compQuery::str_master1];
insert end set k$j [::hwtk::label $recess.k$j -text '****']
$recess.z grid [set l$j] -row $j -col 0 -sticky w -padx 4 -pady 4;
$recess.z grid [set e$j] -row $j -col 1 -sticky e -padx 4 -pady 4;
$recess.z grid [set k$j] -row $j -col 2 -sticky e -padx 4 -pady 4;#default value $recess.e1 set 315;
hwt::KeepOnTop win
}proc ::compQuery::Cancel_func {args} {
catch {destroy .win};
}::compQuery::window
This is a sample using textbox as scrollable window, that you don't need to care about scrollbars
set w .myToplevelWindow ::hwtk::toplevel $w -title 'Sample scrollable window' pack [::hwtk::text $w.t -width 80 -height 25] -side top -fill both -expand 1 pack [::hwtk::frame $w.f] -side top -fill x pack [::hwtk::button $w.f.btnCancel -text Cancel -command ::p_btnCancel_Invoke] -side right -anchor e pack [::hwtk::button $w.f.btnOK -text OK -command ::p_btnOK_Invoke] -side right -anchor e set f $w.t.text.f $w.t.text window create end -window [::hwtk::frame $f] for {set i 0} {$i<100} {incr i} { set lbl [::hwtk::label $f.lbl$i -text 'label [expr 1+$i]'] set ent [::hwtk::entry $f.ent$i -width 20] grid $lbl $ent -row $i }
Hello tinh,
I am running your script in HM 12.
Received following error
Error : Unknown option '-title'
Can you modify this, so i create a subframe inside which is scrollable. @tinh
@tinh i have list of check box inside the frame. I have to make it scrollable.
Hi
There is no option to scroll a toplevel
You have to use text box or canvas widget to do it
Another way, use package BWidget which has tk classes to create scrollable frame and toplevel
